1985 Other Mercedes Benz Models Gears do not change
1985 MERCEDES BENZ
198,000 MILES • V8 • 2WD • AUTOMATIC
GONCALVES
  • 5 POSTS
The reverse and drive gears work on my 1985 MB 500sel, but the forward gears do not shift. Does this mean I need a new transmission?
Armindo
Jan 19, 2008 at 7:55 AM
  • 31,937 POSTS
Hi there,
Check the oil level first, but there is not much else you can do, Have the transmission tested by a transmission work shop, I think that this transmission still used a vacuum modulator, if this is faulty i will cause a gear change problem, Can you select gears manually, Start in 1st and shift up ok, if so the basic power train is ok, so that is an advantage.
Mark (mhpautos)
Jan 19, 2008 at 8:47 AM
