1982 Other Mercedes Benz Models car wont start
1982 MERCEDES BENZ
164,927 MILES • V8 • 2WD • AUTOMATIC
LENDYHOLMES@HOTMAIL.COM
car wont start sprayed starter fluid in carb car starts....i replaced fuel pump and regulator car wont start... disconnect fuel pump sprayed starter fluid in carb car starts.. what do i do next
Thank you for the response I will try it.
Why is it when the fuel pump is connected the car wont start with spraying starter fluid in carb BUT when the fuel pump is disconnected the car will start spraying starter fluid
Jan 14, 2008 at 8:50 PM
  • CERTIFIED EXPERT
  • 31,937 POSTS
Replace fuel filter, remove fuel hose from carby in let and check for fuel pressure & flow there. if ok check carby needle and seat is not stuck closed.
Mark (mhpautos)
Jan 14, 2008 at 9:14 PM
