1999 Mercedes Benz ML430 clicking sound
1999 MERCEDES BENZ ML430
153,000 MILES • V8 • AWD • AUTOMATIC
BUBBA5701
When you turn on the a/c after start up, there is a very audible snapping sound behind the control panel. It will go away as the vehicle cools down or if you turn the temperature level clockwise to the warmer side. Vehicle cools, but very annoying.
Jun 14, 2009 at 3:23 PM
2CARPRO JACK
  • 11,533 POSTS
I have forwarded your question to our M/B tech. He will be with you shortly, thank you for your patience
Jun 16, 2009 at 8:06 AM
GFIMOTORCARS
  • 673 POSTS
This is a common problem on C classes but can happen to other models as well. What you are experiencing is a broken stepper motor armature. This armature transfers movement from this small motor to the blend doors of your ac system. You will notice this mostly at start up as the vehicle does a self test at this time. This is a big repair and often times requires full removal of the entire dash. Typically 4-6 hours of labor but the part is usually under 20 bucks.
Jun 16, 2009 at 4:50 PM
BUBBA5701
what should I expect to pay for the repair? Is this something I can do myself? I am mechanically inclined.
Jun 16, 2009 at 9:22 PM
GFIMOTORCARS
  • 673 POSTS
Depending on the shop you should expect to pay anywhere from $400- $600 for the repair. The part to replace is cheap (below 20 bucks) but this is a very labor intensive job. If you are familiar with MB dash disassembly and complete removal then you could try doing this on your own, however from my experience because of the amount of work involved and the complexity of reassembly I would highly recommend bringing this to a reliable shop.
Jun 17, 2009 at 4:54 PM
