2004 Mercedes Benz ML350 no instuments/dash/heater
2004 MERCEDES BENZ ML350
84,000 MILES • 6 CYL • AWD • AUTOMATIC
RIVKIN101
the fuse for the dash/heater/achas blown 3 times. wife had kids tvs plugged into the cig lihter. dont know if its any co incidence? put in a new fuse lasted for a few hrs then blew again, any help would be reat
thanks
Feb 13, 2010 at 10:25 AM
2CARPRO JACK
  • 11,533 POSTS
Does it blow with the TVs unplugged? Sounds liek you may be drawing too much through that system.If it still blows with the TVS unplugged, you will need to trace out everything in that system to see what is shorting out.Could possibly be the plugs for power , sometimes they can short internally if there is too much pulled through them
Feb 15, 2010 at 12:01 AM
RIVKIN101
still blows even of the tvs are unpluged, someone said poss blower motor resistor
Feb 15, 2010 at 2:26 AM
2CARPRO JACK
  • 11,533 POSTS
That is possible. Try unplugging it to see if the fuse still blows.It is located near at the blower motor
Feb 15, 2010 at 4:03 AM
RIVKIN101
still blows, any other sugg?
thanks
Feb 15, 2010 at 4:20 AM
2CARPRO JACK
  • 11,533 POSTS
Gonna have to isolate every circuit on that fuse and unplug them one at a time until you find the culprit. Have you looked a the wiring for the acc plugs to be sure nothing melted together?
Feb 15, 2010 at 7:15 AM
RIVKIN101
will check that tonight, thanks,
Feb 15, 2010 at 7:28 AM
2 LINSEY
  • 287 POSTS
We appriciate your donation and look forward to helping you in the future. Thank you.
Mar 1, 2010 at 7:47 AM
