My air conditioner makes a loud clicking noise and stops when the temperature is adjusted warmer, after the car has run for a while I can adjust the temperature cooler without the noise. Sometimes the noise will stop within a few minutes, and at times it can take up to 30 minutes. It also doesn't seem to cool as well as it used to and if the car is running idle, it doesn't cool much at all. Do you think this is just a freon problem or something else?
Also, the car just started making a whining noise right after it's started and seems to get louder when turning the steering wheel, but only lasts for about 2-3 minutes. I'm assuming this has something to do with the power steering. Needs power steering fluid? or something else?
Sep 8, 2008 at 12:40 PM
