Has it ever set a check engine light when it is running poorly?If so a scan of the PCM will point in the direction of what is wrong and with which cylinder. If not, you may wind up pulling plugs to visually inspect tehm to see if you can tell which cylinder is burning different
SPONSORED LINKS
Thursday, July 8th, 2010 AT 8:13 AM
