2000 Mercedes Benz CLK430
44,000 MILES • V8 • 2WD • AUTOMATIC
DKNEAL
SHIFT INDICATOR LIGHT IN DASH NOT WORKING AND HALF OF THE CENTER DISPLAY IS DIMLY LIT........IS IT A BULB AND HOW DO I CHANGE IT?
Mar 23, 2009 at 3:22 PM
GFIMOTORCARS
  • 673 POSTS
To replace the bulbs you will need to remove the cluster. This will require a special tool which looks like long thin hooks. This is a MB special tool and I've never seen a aftermarket version. You can probably order them through an MB dealer, that's where I got mine at least. Once you get the hooks you ill push them in between the dash and cluster and by feel will hook the on cluster and pull straight out. The bulbs will simply twist out.
Mar 23, 2009 at 3:54 PM
