1995 Mercedes Benz C280 Oil in Coolant
15,600 MILES • 6 CYL • FWD • AUTOMATIC
MCREWS
I brought my 1995 Mercedes C280 in May of 2008. I noticed what appeared to be oil in the overflow tank for the antifreeze. I had the radiator flush and everything seemed fine. I looked in the overflow just recently and the oil looks like its back in the overflow tank. What could this problem be?
Oct 16, 2008 at 5:32 AM
GFIMOTORCARS
  • 673 POSTS
The problem you are having is being caused by a blown headgasket. The oil is coming from the motor and you may have coolant in your oil pan. This is something that should be fixed asap as you will being to have over heating and enigne lubrication issues.
Jan 6, 2009 at 1:56 PM
