I called wall mart and they said I could bring it back in the moring and they would drain it and put in the right kind. Will this hurt my car. I was always told to use synthic oil.
Also I took it to a shop that works on Benz to get c/a fixed and it still does not work. I wonder if there is a code they need to make it work right, but also they gave it back and the radio does not work. They gave me a code but it did not work. I took it back left it for 2 hrs. They had not even looked at it so I had to go. Can you get me the code and instructions I am kinda done with that shop? Thank you.
SPONSORED LINKS
Tuesday, January 6th, 2009 AT 1:29 AM
