1999 Mercedes Benz C230 blower
EAGERBEAVERS
1999 Mercedes Benz C230 4 cyl
the blower was not working then wipper motor went out as i was cleaning snow off to put wipper motor on i notice on left side of car a hole witch i found out later was where the blower motor is i cleaned out snow and blower worked for a litter while the i had to slam door or hit dash to get blower to work now no mater what i do blower wil not turn on is there a relay out or is there somthing eles and how do i get acess to blower to see if smothing is jaming the blower wheel thanks any help you can give me would help pic or whatever
Feb 1, 2009 at 4:15 AM
JNOVACK
  • 723 POSTS
it is under passenger side dashboard ypu push locking pins to one side pull door down disconnect power to blower and remove screws holding blower in and install in reverse
Feb 1, 2009 at 6:52 AM
JNOVACK
  • 723 POSTS
from you're e-mail it sounds like you have a bad ground in or around the motor try wiggling the wires on the motor to see if you can make it do anything
Feb 2, 2009 at 5:08 AM
JNOVACK
  • 723 POSTS
you do need to remove the leaves and yes it should be tight to the housing but also make sure the wires are tight to the motor
Feb 3, 2009 at 1:32 AM
