1996 Mercedes Benz C200 comp
1996 MERCEDES BENZ C200
89,000 MILES • 4 CYL • 2WD • AUTOMATIC
MARYSMERC
should the comp be engaged on eng run
i start car and few seconds after comp clutch cuts in
if not how does it engage/disengage
never realy sorted out how works
Mar 15, 2009 at 9:26 AM
GFIMOTORCARS
  • 673 POSTS
The compressor clutch engages and disengages based off of the ac pushbutton input. If the air conditioner is on the compressor will engage. However if the ac is off you should have no engagement of the compressor clutch. If you are getting engagement then you may have the begining signs of a bearing siezing in the compressor.
Mar 16, 2009 at 12:34 PM
