1987 Mercedes Benz 560sl
KIMBALDASARE
  • 1987 MERCEDES BENZ 560SL
why does my 560sl choke out, lose all power when it warms up, and then die out?
installed 2 new fuel pumps, fuel injectors, fuel filter, compression check was good, catalytic converter was clogged and has been removed, fuel pressure is good --- what now?
Thursday, October 22nd, 2009 AT 2:19 PM
SERVICE WRITER
  • 9,123 POSTS
Check for vacuum leaks. First check around the throttle body with some carb cleaner to see if the idle changes. You can try this around the intake manifold a well and vacuum lines. Sometimes it requires a smoke machine that injects smoke into the manifold and wil expose a leak.
Thursday, October 22nd, 2009 AT 8:23 PM
