My neighbor has the above described car, but not the internet. He has recently changed out the motor, and is having a problem with, what we feel, is the timing.
The engine # is 117 231hp
He has replaced the timing chain, replaced the hog gear and replaced both cams and gears (2 overhead cams).
Car has difficulty starting, and when running, backfires every 1-2 seconds.
The distributor gear has a little play between the gear and housing, the roll pinion gear appears OK.
Ideas? Jim
Ideas? Jim
May 31, 2009 at 1:51 PM
