Do you have oil getting into your fuel (lots of blue smoke out the tailpipe)?
Or do you have fuel getting into your oil (oil level goes up, the oil gets thin, and you spin bearing and the pistons chew out the sides of the cylinders)? Either problem is more than a "not very car technical person" would be able to fix, but knowing which would help you when you take it in to have someone fix it.
I do have to break it to you that a quality engine rebuild on the M117.985 engine - the one in your car - isn't $4-5K. It's more like $8-10K.
Friday, December 10th, 2010 AT 8:52 PM
