2003 Mercedes Benz 430e Car Battery
FPATRUNO
Electrical problem
2003 Mercedes Benz 430e 6 cyl Front Wheel Drive Automatic
Where is the battery located on the 2003 430 Me Benz
Jan 17, 2009 at 1:51 AM
GFIMOTORCARS
  • 673 POSTS
On e class vehicles the battery will be located in one of two places. Either under the rear passanger seat or under the trunk floor on the right side of the trunk.
Jan 19, 2009 at 8:26 AM
MARCPARADIS
I was wondering if you could tell me how to get the seat up to be able to access the battery?
Mar 8, 2010 at 9:58 AM
GFIMOTORCARS
  • 673 POSTS
There will be two levers you will pull (one on each side of the rear seat) to release the seat cushion. These will between the seat and the floor. The levers are also located nearer to the doors than the middle of the seat. Run your hand between the seat and floor (along the front of the seat cushion) and you should find them. Check right around where the seat cushion starts to make a right angle, near the door.
Mar 8, 2010 at 2:04 PM
