1991 Mercedes Benz 420sel Brakes
180,000 MILES • V8 • 4WD • AUTOMATIC
THEO ZICKO
How difficult is it to replace L & R rear calipers, pads and sensors on this car? I have done this on an early model Volvo but on this car I do not know. Right now after installing a new master cylinder, the rear
caliper pistons that hit the disk now do not withdraw completely and consequently it feels llike a slight drag while the car is moving. The sensors apparently are constantly in contact because they are melting. I have tried lubricating the pistons that fail to withdraw once your foot is off the brake but they fail to do so. Any suggestions as to how I can correct this problem? I guess the new master cylinder is exerting too much pressure on the old calipers. Can removing some of the brake fluid help the situation?
Jul 20, 2010 at 6:17 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Recheck part number for master for your car make sure it is for a four wheel disc brake. If master is for rear drums it has a check valve that holds residual pressure to rears so caliper will be partialy applied.
Let me know
Thanks for donate
Jul 20, 2010 at 7:57 AM
