Replacing fuel filter?
RICHARD SOMMERY-GADE
  • 1982 MERCEDES BENZ 380SL
  • V8
  • 93,000 MILES
Where is and how do I access the fuel filter to replace same. Have looked under car where most MBZ fuel filters are located, but I don't see it. I am disabled vet on social security, that is why I am fixing this myself.
Monday, January 18th, 2010 AT 11:53 PM
The fuel filter is near and above the rear differential
REPLACING FUEL FILTER
http://www.2carpros.com/forum/automotive_pictures/12900_ffm1_1.gif
*Remove protective cover.
*Disconnect fuel lines.
http://www.2carpros.com/forum/automotive_pictures/12900_ffm2_1.gif
*Loosen mounting screws (arrows) and remove filter.
*Unscrew fitting from old filter and attach to new filter with new seal ring.
*Install new fuel filter in flow direction with plastic sleeve.
*Sleeve should project on both sides of the holder since contact corrosion may occur if there is direct contact with the holder.
*Replace plastic sleeve, if necessary.
*Connect steel line to filter.
*Retighten mounting screws.
*Check for leaks.
Tuesday, January 19th, 2010 AT 12:29 AM
Thank you very much for the help. Mahalo and Aloha from Hawaii.
Tuesday, January 19th, 2010 AT 12:40 AM
Related General Content
