1985 Mercedes Benz 380se V8
I have a 85 mercedes 380se when I start my car cold it starts fine runs fine, then after 20 seconds about, the engine begins to stall or may want to, will stall if put in gear reverse or drive or may want to, but then stops after is getting warmed up or at operating temperature. New spark plugs. could it be running lean. How do you adjust fuel/air mixture
Aug 9, 2010 at 10:52 PM
