1983 Mercedes Benz 300sd right front seat
1983 MERCEDES BENZ 300SD
MIKE SAMPLES
Interior problem
1983 Mercedes Benz 300sd 4 cyl Two Wheel Drive Automatic 237.00 miles
my right front will not move forward although the motor is running thanks
Feb 10, 2009 at 1:28 PM
2CARPRO JACK
  • 11,533 POSTS
I have forwarded your link to our resident M/B expert. He should be with you shortly
Thanks for using 2CarPros.com
Feb 10, 2009 at 11:36 PM
GFIMOTORCARS
  • 673 POSTS
This is more than likely a broken seat motor armature/cable. If you look carefully under the seat and follow the motor you should see an armature that leads off of it. Often times this armature breaks and often it is even visable as a broken cable under the seat. However sometimes the break is not as obvious. You described the motor as still running so the motor still works, only thing between the motor and the seat is the armature/cable that transfers the the power from the motor to the seat.
Feb 11, 2009 at 3:49 AM
