1997 Mercedes Benz 300d fan clutch thread
1997 MERCEDES BENZ 300D
PLAYERE
  • 6 POSTS
1997 Mercedes Benz 300d Two Wheel Drive Automatic
hey i wanted to know does the fan clutch for a 1997 mercedes E300D have a reverse thread...if not is it right threaded or left. I am having a hard time trying to get it off and I ould like to know which way I need to go without strippeing the threads if I havent already done so.
Dec 12, 2009 at 2:47 PM
  • CAR REPAIR CONTRIBUTOR
  • 31,937 POSTS
Hi there, Could you please re check the model info as there is no 97 E300D in the data base.
Mark (mhpautos)
Dec 12, 2009 at 4:38 PM
PLAYERE
  • 6 POSTS
hey the model of the car is a 1997 mercedes benz E300D diesel. could it be possible if it could be part of the E class. I asked a question about the fan clutch last week. I got some great advice but I forgot to ask is the fan clutch bolt is right or left threaded..I hope this helps
Dec 12, 2009 at 5:15 PM
  • 31,937 POSTS
Hi there,
If you just add this question to the the thread of your last one, the mod who was helping you will get a direct note to check this out, he will already have the correct car found on his data base, and he should be able to check this ASAP, if not re post here an i will look into it for you a bit further.
Mark
Dec 12, 2009 at 6:36 PM
PLAYERE
  • 6 POSTS
is the fan clutch bolt is stripped is it possible to use jb weld to held get it out since i would have to replace bolt anyway
Dec 13, 2009 at 5:37 PM
DR LOOT
  • 2,311 POSTS
if my memory serves me correct the nut on the fan is 1''1/4, is that correct?
Dec 13, 2009 at 11:57 PM
