1987 Mercedes Benz 300d power steering leaks
TERRYIDC
  • 1987 MERCEDES BENZ 300D
  • 6 CYL
  • 250,000 MILES
The power steering leaks under the steering box
which I cannot see from where. What is the possible
repair involved qnd the easiest way to do it.
Thanks
Tuesday, December 30th, 2008 AT 3:55 PM
DR LOOT
  • 2,311 POSTS
There is never any easy way to do it! You know what I mean when you're trying to get your girlfriend or your wife hot! "To do it" there is never any easy way. At any rate, I am trying to help you fix a problem that you say "I cannot see from where" that is like the blind leading the blind, will they both not fall into the ditch? If you can't see it, I surely cannot see it, why don't you try this, go to your local car wash open up the hood take the pressure washer clean around the steering box, and then get on your knees (and pray of course) and wash underneath the steering box, then drive it home and see if you can find out where it's leaking from and get back to me.
Saturday, February 21st, 2009 AT 7:59 PM
