1984 Mercedes Benz 300d 4th gear
1984 MERCEDES BENZ 300D
ORVIE6574
Transmission problem
1984 Mercedes Benz 300d Two Wheel Drive 209,00 miles
I have to go around 70, for it to shift into 4th, the car sat for awhile, and thats when iit started to act up, I have changed the filter and oil, some times it wont shift at all,
Nov 2, 2009 at 7:03 AM
DR LOOT
  • 2,311 POSTS
That particular transmission shifts on the vacuum, make sure your vacuum pump is good, it could also be a takedown linkage, located on top of the vale cover, it's that unit full of vacuum lines, check all your life, make sure they are good.
Nov 26, 2009 at 11:35 AM
