1988 Mercedes Benz 300ce Water leak
1988 MERCEDES BENZ 300CE
SAMR9TH
Engine Cooling problem
1988 Mercedes Benz 300ce 6 cyl Two Wheel Drive Automatic
How can I Know for sure my coolant leak is my water pump (the pump holds some water at lower hose) and not the head gasket or freeze plug. I can see the water coming from under the A/C bracket and looks to be seeping from bottom right corner of pump; even though pump has new seal.
Jul 18, 2010 at 1:16 PM
DAVE H
  • 13,384 POSTS
do a pressure test of cooling system
Jul 18, 2010 at 1:41 PM
WRIGHTIMC
