Jerks While Driving
JRSTEINMAN
  • 8 POSTS
I know this is most likely the fuel pump, but I am seeing if anyone has any other suggestion.
I have a 1994 B3000, When I am driving in second gear or higher my truck jerks like it is miss firing. It is exceptionally worse under any load or going up hill. I have replaced fuel filter, plugs and wires just recently, so I know it isn't any off that stuff. So let me know if you have any thoughts.
Nov 23, 2007 at 5:35 AM
  • 75,988 POSTS
Check the fuel pressure,throttle position/MAF/MAP sensor/engine load sensor and for exhaust restriction to rule out the catalytic converter.
Nov 27, 2007 at 7:33 AM
