Yes, it is 4 door. Doesn't come on while driving no matter what bumps I run over. I've tried pulling on the wiring that runs through the flexible connection at the door hinge, and after "several" attempts at that, I can get the lights to go off. Unfortunately,I deliver Pizza at night and this is really cutting into my runtimes, fussin' and what not. been almost to the point of ripping the wires out but I know that will only help everything go south real quick..Are the sensors magnetic? Electromagnetic?
[quote:e499b8ca3f="Cosmo"]Well the door ajar switch is in the door panel itself and part of the door latch....its a little tricky to get at though, even with the trim panel off.
Another question is.....does your truck have four doors? If so make sure that the upper and lower latch are latching....if not the front doors can move engouh to turn on the dome light when going over bumps or when the cab flex's
Cosmo...Mazda TEch[/quote:e499b8ca3f]
Jan 2, 2007 at 3:25 AM
