89 MAZDA B2200 IGNITION TUMBLER BROKEN
2012 MAZDA TRUCK
IBDRINKEN
The key broke off in my ignition and I was wondering how hard it is to change out the tumbler and how would I go about it.
Nov 10, 2007 at 3:27 PM
BLACKOP555
  • 10,386 POSTS
well if the key is on the on position when it broke out then not hard at all.
if its not in on or will not let you put it in the on position you have to take a smal drill and find the little hole on the tumbler's housing and drill it out then the ignition tumbler should come right out.
if you can turn it to on do so and take a punch or paper clip and push in the hole and pull out on the tumbler at the same time.
Nov 11, 2007 at 12:23 AM
