1993 Mazda B2600 Diagnostic Port Location
Cosmo...Mazda Tech
Suggested Repair
Look under the hood on either fender for two green connectors. The six-pin connector is for factory diagnostic equipment. With the key on, ground the single-pin green connector with a jumper wire so the check engine light flashes trouble codes. If the light does not flash, the engine light may need to be reset at a dealer.
Conversation Summary
The owner of a 1993 Mazda B2600 asked where the diagnostic connector is and how to retrieve trouble codes with an LED or by jumpering pins. A Mazda technician said there are two green connectors under the hood on a fender: a six-pin connector for factory equipment and a single-pin connector. Grounding the single-pin connector with the key on should make the check engine light flash codes; if it does not, the light may need a dealer reset.
