Replaced the alternator (that was unbelievable), cable are okay, new battery, fuses good. where do I go from here?
Jun 5, 2010 at 4:20 AM
✓Experienced Mechanic
I'm going to first suggest checking the alternator to confirm it is working. It is easy to do and only requires a voltmeter or a multimeter. Here is a link that explains how it's done:
Now, if the alternator is charging properly, then it is likely you have a parasitic draw. Here is a link that will help you identify where the draw is coming from and how to repair it:
