RX-7 Toe/ Suspension ?
MAZDA RX7
ROTAR-BOI
Hi i just recently brought an 1983 Series 2 RX-7.
it had been in a slight accident, left side had some damage. mainly panel. but today i wen to replace the front left wheel which was flat. checked out the brake lines, rotor and pads which all seem fine.
put thenew tire on, but once lowered, i felt over and it was pushing right on the suspension.
Their seems to be no damage to the tie rods or anything else around that area..... any suggestions?
Aug 7, 2007 at 7:33 PM
DTKNIVES
Disco's have a "roll over" switch that turns off the pump should this event occur. It's located on the firewall on right side of vehicle.
Most failures are the fuel pump itself but sometimes the wiring in the connector to the pump gets burned or corroded. Always check the wiring when replacing the pump.
Nov 4, 2007 at 6:32 PM
