Protege engine knocks at high speed
MAZDA PROTEGE
ACCELO
Mazda Protege 2001, 200K miles. Engine runs well at low speeds but knocks at high speed and "Check engine" light comes on. Mechanic suspects I might need "valve work" but not sure. I can drive around town, but not on the freeway because of the hard knocking sound at high speed. What do you think ?
Jan 6, 2007 at 8:18 PM
200K miles is in the border of its life-meaning an engine rebuild
Where is that knocking coming from the engine- Is it clacking, tapping or more like a thumping or bumping.
Can be a valvetrain, engine bearings, clogged oil galleries,and weak oil pump that the oil is not reaching all the way up.
Sometimes Doing an engine flush thouroughly might help.
What is the OBD2 code
Have the knock sensor check and ignition timing
HTH Good Luck!
Jan 6, 2007 at 8:33 PM
