2002 Mazda Protege No Crank After Impact
MCL73
2002 Mazda Protégé, milage 42000, I rear ended another car at a slow speed (less than 15 mph) due to extremely slick road. Their car did not show any damage at all, mine has a cracked front bumper and crooked front grill, radiator untouched, airbag did not go off, headlights untouched, engine hood in perfect shape, no fluid spill. My car was running after the impact then I turned the engine off and removed the key. Ten minutes later I wanted to start the engine again and it does not crank at all although the dashboard lights up as usual. Is this the starter that gave up? To make sure that nothing got disconnected by the impact, which cables/connectors should I check myself and where are they?
Bigger problem yet is that the gear selector moves almost without any resistance through the gears and the car can be pushed forward and backwards even when in gear (D, 1, 2) or in “P” position. Is the transmission busted? How expensive would the repair be in this case. I will greatly appreciate any help/suggestions, thanks a lot!
Michael
Dec 23, 2006 at 6:39 PM
COSMO
  • 347 POSTS
If the car was hit in the left front you may have broken or damaged the shift cable going ot he transmission, which is located at the left front of the vehicle...if the gear selector on the transmisson gear switch does not read park or neutral to teh computer....it will not crank the motor...even if the gear selector in the car is in park or neutral.
The selector can be seen under the air bow of your car near the bottom of the transmission....follow the big black cable with a rubber boot on the end, to the gear selector switch to see if there is any damage.
Cosmo...Mazda Tech
Dec 24, 2006 at 10:49 AM
Suggested Repair
Inspect the transmission shift cable and gear selector switch at the left front of the transmission, under the air box. Follow the large black cable with the rubber boot to the switch and look for impact damage. If the switch does not signal Park or Neutral, the engine will not crank even when the cabin selector is in those positions.
Conversation Summary
After a low-speed front impact, a 2002 Mazda Protege had bumper and grille damage, would not crank despite normal dash lights, and the shifter moved freely so the car could be pushed in gear or Park. The expert said a left-front hit may have damaged the shift cable or gear selector switch, preventing a Park or Neutral signal and blocking cranking. They advised checking the selector under the air box by following the black cable with the rubber boot.
