CIRCUIT TEST
Ensure battery is fully charged, battery cables and terminals are clean and tight, and engine grounds are okay. If starter does not operate, measure voltage at starter "S" terminal (Black/Red wire) with ignition switch in START position (ensure clutch is depressed on M/T or gear selector in Park on A/T). If voltage is greater than 8 volts and vehicle does not crank, repair or replace starter as required. If voltage is 8 volts or less, check ignition switch, park/neutral switch (A/T), starter interlock (clutch start) switch (M/T) and wiring.
Oct 19, 2009 at 11:59 AM
