1993 Mazda Protege DX
1993 MAZDA PROTEGE
LESLIEMCOV
1993 Mazda Protege
I own a 93 mazda protege. I stopped for gas, was running really low and the car never started again. We have changed the fuel pump, fuel pump relay, distributer, computer, ignition, coil, igniter.
Timing belt is good.
Fuel pump doesnt come on with the key but does run when tried with a jumper. Not getting fire to the the spark plugs but has power to all ignition components.
Is there a reset button for the fuel pump?
I also read on someone elses answer that their computer had to be reset?
Any help would be apprecitated.
Mar 27, 2010 at 1:04 PM
Inspect and test main relay, circuit opening relay and Ignitor
Mar 28, 2010 at 2:28 AM
WENDELL123
  • 23 POSTS
you change the coil and the distriberter car wont start on a mazda pretege if you look right beside the coil theres a little black box that is your ignition module replace that and your engine will start again how i know i have a mazda protege that will complete the circut.
Jun 19, 2010 at 8:52 AM
