1992 Mazda Protege
J_TASHARA
  • 1992 MAZDA PROTEGE
Engine Performance problem
1992 Mazda Protege 4 cyl Front Wheel Drive Automatic
car has been sitting for a while needed a new starter switch had new starter installed now tries to crank but will not catch fuel pump is working filter has been blown out fuel line has been checked for pinches checked the fuses
Tuesday, July 27th, 2010 AT 8:02 PM
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
Wednesday, July 28th, 2010 AT 10:25 AM
