1993 Mazda MX-3 Brake and Fuel Lines
MELISSA
I was recently told that I will need new brake lines, and fuel lines in order to sell my car saftied. Is this worth doing? There's not much else wrong with the car, it's a 93 with about 136 000km's. Any advice, or places to get cheap parts would be helpful as well
Thanks
Jan 11, 2006 at 3:17 AM
2CARPRO JACK
  • 11,533 POSTS
2CarPros editorial correction - October 12, 2026
The earlier assertion that metal brake and fuel lines should outlast the car has been withdrawn. Corrosion and damage require inspection; age or the absence of an obvious leak does not establish that a line is safe. Ask the inspecting shop to show the affected areas and provide a written repair estimate. Do not drive with leaking fuel, a brake-fluid leak or impaired braking; arrange appropriate recovery and repair.
Jan 18, 2006 at 9:43 AM
COSMO
  • 347 POSTS
This reply has been revised to remove personal criticism and unsupported blanket statements about inspection rules. Have the brake and fuel lines inspected for corrosion, damage and leaks, and obtain a repair plan using suitable automotive materials and approved procedures for the actual vehicle. Whether a particular repair meets an inspection requirement must be checked with the applicable local authority. No inspection findings or completed repair were supplied for this MX-3.
Jan 18, 2006 at 2:07 PM
Suggested Repair
Have the brake and fuel lines inspected for corrosion, damage, and leaks. Ask the shop to show the affected areas and provide a written repair estimate. Do not drive with a fuel leak, brake-fluid leak, or impaired braking; arrange recovery and repair. Use suitable automotive materials and approved procedures, and confirm inspection requirements with the local authority.
Conversation Summary
The owner of a 1993 Mazda MX-3 with about 136,000 km was told new brake and fuel lines were required to sell the car with a safety inspection and asked whether the work was worthwhile and where to find inexpensive parts. Corrected expert replies withdraw earlier claims that metal lines should outlast the car. They recommend inspection for corrosion, damage, and leaks, a written estimate, not driving with leaks or impaired brakes, proper materials and procedures, and verification with the local authority. No inspection findings or completed repair were provided.
