1999 Mazda Miata Overheating
FARAY
1999 Mazda Miata 165000 miles 1.5Liter
(If my question sounds strange, its because I speak girl language so you will have to translate it to yours).
Engine heats up in slow traffic as is generally a problem in Dallas. This has happened before and I replaced radiator and 1 fan (approx. 2 yrs ago).
Now I am noticing the problem even at a higher rate of speed. I was driving yesterday (temp outside 104 degrees) at about 70 mph and noticed air conditioning was not cooling. Checked the engine temperature indicator and noticed it was increasing. I simply turned AC off and on intermittently whenever temp increased. I checked coolant and it seems to be OK. This is not a constant problem and seems to occur only during summer days of extreme temperature. It also happened as I circled parking lot looking for a parking space. Can you give me any idea what might be going on as it gets awfully hot without AC here.
Aug 15, 2007 at 1:58 AM
  • 75,988 POSTS
[quote:1df1e9ad0e="faray"]1999 Mazda Miata 165000 miles 1.5Liter
Now I am noticing the problem even at a higher rate of speed. I was driving yesterday (temp outside 104 degrees) at about 70 mph and noticed air conditioning was not cooling. Checked the engine temperature indicator and noticed it was increasing. I simply turned AC off and on intermittently whenever temp increased. I checked coolant and it seems to be OK. This is not a constant problem and seems to occur only during summer days of extreme temperature. It also happened as I circled parking lot looking for a parking space. Can you give me any idea what might be going on as it gets awfully hot without AC here.[/quote:1df1e9ad0e]
Could be the thermostat getting lazy-get it replace and see what happens. Is the cooling fan working as designed.
Aug 15, 2007 at 9:19 AM
Suggested Repair
Replace the thermostat, which may be sticking or opening late, and confirm the cooling fan operates as designed.
Conversation Summary
A 1999 Mazda Miata with 165,000 miles overheats in extreme summer heat, including slow traffic, parking-lot driving, and at about 70 mph. The radiator and one fan were replaced about two years ago, and the coolant level appears normal. Turning the air conditioning off temporarily helps when the temperature rises. The expert suggests the thermostat may be failing and should be replaced, and asks whether the cooling fan is working properly.
