Load leveing suspensions
CHESTERTHECAT
  • MAZDA MPV
Make: mazda MPV
year: 1992
engine: 3.0 liter V6
milage: 130000
question:
when I have my car parked in my car port over night. I seem to lose air pressure in my shocks. Then when I start in the moring it has to level the van for about a minute. Then stop when it is level. I have a load leveling shocks that came with the van when I bought it new with a towing package. This was never the case of it having to level over night before only when I have a load then it will adjust or relevel itself. Do I need new air shocks? But if I just stop for a little while like 2 hours it does not have to relevel itself. However I just dive it today and it still have to relevel a little bit only for a second or two.
thanks very much for your attention to this matter.
Monday, February 27th, 2006 AT 1:37 AM
POLLY
I own a 1992 mazda mvp 4 wheel drive, milage 166,800. Automatic.
Every time that I shift from park I blow a fuse, which operates all gauges, heater buttons, tow package(will not shift out of tow gear). Loss of power when I first start driving, will not shift out of park, no blinkers. Any idea why fuse would continue to blow.
Thanks
Polly
Friday, March 24th, 2006 AT 1:04 PM
CHESTERTHECAT
Hi polly,
from my experience, I think you should ask your mechanic to check out the ignition switch, the one where you put the key in and when you start the car or even when you turn it off there is a short at that point or even trace it from there.
I hope this help, goodluck.
Monday, March 27th, 2006 AT 3:49 AM
Related Suspension Shock Content
Rear Shock Absorbers
VIDEO
