2000 Mazda MPV Starting Idling Loss
2000 MAZDA MPV
90,000 MILES • 6 CYL • 2WD • AUTOMATIC
PBIDANJIRI
When I start the vehicle after some hours of interval, it requires several starts before holding idling speed. The number of times I have to start for it to hold idle speed varies randomly from 10 to even 20 and sometimes I just start driving it by using both the accelerator pedal and the brake pedal.
Thanks!
Jul 19, 2010 at 10:12 PM
EDWARD.S
  • 166 POSTS
Hi, Have The computer Checked Out For Codes first. If no Codes .Clean throttle body . If It Still Not Work You May Need A Idle Speed motor.
Hope This Helps You,
Good luck
Edward S.
Jul 19, 2010 at 10:52 PM
