2000 Mazda Miata Check Engine Light
GLOWLUZ
My Mazda Miata failed the smog test...which I don't understand because in the report shows that pass everything except for the VISUAL Inspection, Malfunction indicator light.
About a month ago I noticed that I had a red light
indicating "Check engine"...in the past it used to happen when I didn't close the gasoline gasket , so I closed the gasket really hard...but still the light was there...so my question is: what do I have to do to get rid of that light and pass the smog test.
My odometer reading is 39322.
May 1, 2006 at 10:42 AM
CHIPSAHOUY
When the check engine light on my 2002 Mazda Tribute wouldn't go away after tighting the gas cap several times and following the owner's manual instructions on how to get it to reset we had to take it back to the dealership (was still under warranty). We were told by the dealership that the gas cap itself needed replaced. The cap was approx. $100. Two weeks later the light reappeared, so back to the dealership and then they indicated it was some emissions sensor. I wasn't going to pay another $100 since they obviously didn't check everything out the first time around and they ended up eating the $100 deductible for the sensor replacement.
Good luck!
May 3, 2006 at 12:10 PM
COSMO
  • 347 POSTS
ok,
you are going to have to get the engine light turned off at a shop or dealership. Although a 'loose' gas cap might have been the initial cause of the engine light, tightening it will NOT turn off the light. There is NO gas cap tightness sensor.
A quick corse on engine lights: 1. Most of the time when engine lights come on its when the PCM (computer) has seen a 'fault' occur more than three times in a specific amount of time.
2. After a set specific amount of time after the PCM turns on the light, if the computer has not seen that 'fault' again, it will shut OFF the engine light BUT the fault code is still stored in the PCM for retieval by a tech.
3. On Mazda's there is nothing the consumer can do to turn off the engine light in the way of key cycle's or gas pedal depressions. THe two ways are scan tool (duhh!) and disconnecting the battery (but beware you will loose all of your radio stations and the PCM and TCM have to re-learn your driving habits)
So in closing, I would get you car to a shop to get the engine light checked out since your light comes on and off, this indicates that the PCM is seeing a fault occur every once and awhile.
Cosmo...Mazda Tech
May 4, 2006 at 11:14 PM
Suggested Repair
Have a shop or dealership scan the PCM for stored fault codes and diagnose the intermittent check engine light. Tightening the gas cap will not turn the light off. A scan tool is the proper way to read and clear it; disconnecting the battery can turn the light off but erases radio presets and forces the PCM and TCM to relearn, and the underlying fault should still be checked.
Conversation Summary
A 2000 Mazda Miata failed a smog visual inspection because the malfunction indicator (check engine) light was on. The owner thought a loose gas cap was the cause after tightening it did not clear the light. Another owner described a different Mazda where a gas cap and later an emissions sensor were replaced. The Mazda tech explained that a loose cap may have triggered a fault, but tightening it will not extinguish the light, and there is no gas-cap tightness sensor. On this Mazda the light cannot be reset by key cycles or pedal presses; a scan tool or battery disconnect can turn it off, but an intermittent light means the computer is still seeing a fault and should be diagnosed at a shop.
