1998 Mazda b4000 wipers dome light 4x4 switch intermitant
1998 MAZDA B4000
NOZZANO22
I have noticed that at times the wipers, dome light and 4x4 selector switch do not work. sometimes they will start working while I am driving. All fuses are good. I had a local shop check for codes while the problem was ocuring but nothing showed up. While the scanner was hooked up the wipers made one pass then the problem continued.
I have not noticed any correlation to outside temp, engine temp, or other electrical functions.
Is this the GEM or Body Computer module? anything else I should check before replacing that?
Mar 15, 2010 at 11:02 AM
MERLIN2021
  • CAR REPAIR CONTRIBUTOR
  • 17,250 POSTS
Could be, but it could also be a bad ground Check at these two locations. I will send you the wiring diagram, also check the connectors at each part...
https://images.2carpros.com/forum/automotive_pictures/62217_grounds_1.jpg
Mar 15, 2010 at 2:50 PM
NOZZANO22
I located a used GEM but will try your suggestions first.
It does seem odd that it is intermitant. I would think the GEM would either work or not.
Are these ground straps found inside the engine bay of the vehicle? If I remove, clean and reinstall is that adequate?
Should I also check, clean the GEM connectors? Dielectic grease?
Mike
Mar 15, 2010 at 3:17 PM
MERLIN2021
  • 17,250 POSTS
Grounds are under the hood, remove the negative battery cable, then work on your connectors and grounds, very light on the dielectric grease, and plug em back in. Clean the grounds, but dont remove any paint on the grounding surface.
Mar 15, 2010 at 3:41 PM
JCOFFMAN
I'm having exact same issue. Give me a call mike if u don't mind walking me thru what u found to fix. Thanks. John. 812-528-2881
Feb 8, 2015 at 10:22 AM
