1992 Mazda b2200 truck keeps blowing the engin fuse
REBELBADBOY
Electrical problem
1992 Mazda b2200 4 cyl Four Wheel Drive Manual
why does my 1992 mazda b2600i keep blowing the engin fuse when i drive it down the road or just sitting in the yard when i crank it up sometimes but now its goton worce just wondering
Sep 3, 2008 at 8:21 AM
ASL3762
  • 6 POSTS
check your distubutor may have to replace it an or the 3 hot wires on coil, check those wires make sure they are not shorting out, a test light would help you out
Oct 14, 2008 at 6:03 PM
PLUMBICBLIMP
if you're fuel level indicator also isn't working, it may be that the ground wire in the fuel tank that attaches to the level float has fallen off due to normal wear. This happened to my truck and it died a couple times on the road.
Dec 15, 2008 at 4:39 AM
