Engine Vacuum Lines
STEVEANDCARON
  • 1992 MAZDA B2200
  • 233,000 MILES
I have a 1992 Mazda B2200 and I was wondering if anyone out there could send me photos of what they are (where they are located) so I can reinstall new vacuum lines on my truck (carbureted):
Primary Main Air Bleed,
Secondary Main Air Bleed,
Idle Compensator,
Secondary Venturi,
Float Chamber
All of these are hook ups for vacuum lines. Thank you in advance!Steve
Monday, January 9th, 2012 AT 7:33 PM
DOCFIXIT
  • 18,828 POSTS
Here are the engine vacuum line diagrams below. Please let us know if you need anything else to get the problem fixed.
Cheers
Tuesday, January 10th, 2012 AT 3:40 PM
JIMLAW45
  • 1990 MAZDA B2200
Engine Mechanical problem
4 cyl Two Wheel Drive Manual 250000 miles
I have a 1990 Mazda B-2200 2.2L manual-5 speed and my vacuum lines on the carburator are incorrect such as Duty Solrnoid, High Altitude Compensator, Vacuum Control Valve, EGR Control Valve, ACV Solenoid Valve, Purge Solenoid Valve, No-2 Air Control Valve etc etc. And its using to much gas. I had someone put another carburator on it because the float was hanging up showing all the way to the top of the sight glass but he didnt mark the lines to hook them back right. I will send you some money for A print out or pics on getting them right Thanks:
Tuesday, October 2nd, 2018 AT 10:09 AM (Merged)
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,654 POSTS
Here are the engine carburetor and emission vacuum line diagrams to help you get the truck back on the road. (Below)
Cheers, Ken
