1988 Mazda b2200 running rough
1988 MAZDA B2200
354,000 MILES • 4 CYL • 2WD • AUTOMATIC
GRAEME72
my truck runs rough,it backfires and stutters on hills and will die, i have changed wires,plugs, air and oil filter, i do not know where fuel filter is, i suspect this may be the issue but i am not a mechanic.what do u think the problem is, also on start up i need to sit in the truck and keep the revs up until it warms up or it will die, pls help
Feb 22, 2010 at 8:50 AM
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug.
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
Feb 22, 2010 at 10:45 AM
