1986 Mazda b2200 Fuel system
65,000 MILES • 4 CYL • 2WD • MANUAL
ANDREWHERSHFELD
I just replaced the feed line goin from the tank, to the fuel filter in the engine capartment. Also replaced the carburetor. It fires up and will run for about 5 mins, then dies and wont refire for a while. What can I do to keep it running. Ive tested the fuel pump and it seems to be working fine.
Sep 2, 2009 at 7:08 AM
  • 75,988 POSTS
Check the coil, distributor pick-up coil and ignitor-
Sep 2, 2009 at 7:44 AM
ANDREWHERSHFELD
already have, all are in working condition
Sep 2, 2009 at 8:33 AM
  • 75,988 POSTS
Check and test the air/fuel solenoid valve and idle switch-both okay get the emission control unit checked out-
Sep 2, 2009 at 8:41 AM
