Trunk problem
CZEHAN10
I have a Mazda 626 , 2.0 L 1994, 138K miles.
When I bought the car, it didn't have a trunk key, which I didn't care much, because I could open the trunk from the inside. Recently,I can't open the trunk from inside, anymore. My question is: The trunk key is different from the ignition key(I tried mine and it didn't work), Where, and how I can get a new trunk key?
Aug 2, 2007 at 10:13 AM
JAYKIDD
  • 5 POSTS
there is somethin wrong with ur lock for ur trunk all mazda ignition keys will fit in their own trunk...if u cant open it up from the inside any more lower down ur backseat and crawl into ur trunk the latch that lets the trunk open is bent in to far so if u unbend it a little bit then the lever by ur door should open it if that dont work then ull have to replace the lock on ur trunk to fit ur ignition key
Aug 5, 2007 at 5:08 AM
