Cooling Fan keeps running
MAZDA 626
RODDY
I have a 1999 Mazda 626 LX-V6. After using the A/C, the cooling fan (on the passenger side of the car, I believe) keeps running. I have resorted to pulling a fuse as a temporary fix. However, my A/C won't cool without the fuse so it's not a good long term solution. Any idea why the cooling fan won't quit? It will run down my battery if left unchecked.
Mar 1, 2006 at 6:45 AM
JS46767
  • 7 POSTS
i had the am problom in a dif. car i found out that the relay swtich was stuck try the relay switch.
hope that helps
john
Mar 2, 2006 at 1:31 PM
