I have a 2000 mazda 625 and the over drive light keeps flashing on and off. It will not kick out gear until I release the gas. I can not go over 40 because it will not shift out of 3rd. What can I do
Sunday, March 30th, 2008 AT 6:19 AM
MASTERTECHTIM
MECHANIC
You need to have the computer for the transmission scanned for codes then go from there. You probably have a electrical fault. Get back to us
SPONSORED LINKS
Sunday, March 30th, 2008 AT 7:28 AM
SERVICE WRITER
MECHANIC
You need to find what codes are in the computer.
I expect based on the symptoms it is going to be PO743-TCC valve solenoid circuit failure. IT may be a solenoid failure, circuit wiring problem, bad PCM ora connctor problem between the pcm and the TCC.
First the codes need to be accessed with a scanner. Once you have (it) them, post back.
Sunday, March 30th, 2008 AT 7:29 AM
MERLIN2021
MECHANIC
Could be TSB# CAT.05, NO 005/02 If you also have stored codes P1783 and P1718, if
you do the cure is to add an external atf oil cooler. This also involves a new
radiator! Failure to follow this TSB can result in tranny failure, Check for these
codes if the flashing light goes out after the tranny cools below 135 degrees, and
the car is restarted. If this does not match your symtom, , the TSB does not apply!
