1999 Mazda 626 Engine not working
98,000 MILES • 6 CYL • 2WD • AUTOMATIC
COOPERRACK
My daughter was driving my son's 626 and it kept overheating. She kept putting water in the engine but it finally stopped wprking. I put water in it again and it did not leak. The oil looks fine. I took it to a local dealer and they said the engine was blown. I can understand that, no water - no work. My question is that they just looked at it and turned the engine over and the starter only worked. They did not take anything apart or look at any of the parts of the engine. My question is about the degree of serious damage. How do I know the block is seized or it might be some other problem? Are there other heat related problems that could cause the engine not to turn over? I guess I need to know what steps I can go through to finally diagnose the problesm? Thank you for having a site like this to help us.
Sep 2, 2010 at 4:22 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Dealer was going off of experience and sound of engine cranking with no compression. Most likely damage will be headgasket failure and warped or cracked head. If it was driven long enough and hot enough then piston ring and cyliner wall damage may have occured. A compression test and cylinder leak down tests will helpdetermine how bad things are. But engine teardown and repair of components is needed or replace engine.
Hope this helps
Thanks for donate
Sep 2, 2010 at 4:34 AM
