1998 Mazda 626 Alternator replacemnt
THENDERSON4
Electrical problem
1998 Mazda 626 4 cyl Front Wheel Drive Automatic
How do I replace the alternator on my daughter's 98 626. I see the top mounting bolt and belt tensioning adjustment bolt. Is there one under the bottom and how do I get to it?
Mar 9, 2009 at 4:41 AM
JAMES W.
  • 2,394 POSTS
Yes there is a bolt running through the bottom of the alternator holding it to the mounting bracket. You should be able to access it with a 6' extension and either a 13 or 15 mm socket. Note, be sure you disconnect the negative battery cable before you start the work. Also, with disconnecting the battery, you may lose radio memory, so if it needs a reset code. Be sure you have it.
Mar 9, 2009 at 6:17 AM
THENDERSON4
Do I remove the right front wheel and perhaps a shroud (splash guard) or just get the car up on jack stands and go at it from the bottom?
Mar 9, 2009 at 3:27 PM
JAMES W.
  • 2,394 POSTS
Jack stands may do the trick. Just be sure it's secure. You still may have to remove the splash guard.
Mar 9, 2009 at 3:33 PM
