1997 Mazda 626
JRA20
  • 1997 MAZDA 626
  • 6 CYL
  • MANUAL
  • 150,000 MILES
My car will not go into gear. When I push the Clutch in it push in fine, but when I try to put it into to gear I met resistence. A few times I could make it through the resistence and after that it shifted fine the rest of the day.
Well I woke up this morning to try to make it to work it and it wouldent go into to gear.
Do you think if I put fluid into my clutch master cylinder it may temporarily solve the problem? Or do I need to replace the clutch?
Thursday, April 24th, 2008 AT 9:47 PM
  • 31,937 POSTS
Hi there
check the clutch operation and make sure the fluid is full, if very low, you will have to check for a leak at the master and slave Cly. Also have the transmission oil checked for correct level as well.
Mark (mhpautos)
Friday, April 25th, 2008 AT 1:59 AM
JRA20
I found the master cylinder thats connectd to my transmission but I cant seem to find the spot to check my fluid.
Friday, April 25th, 2008 AT 2:47 PM
  • 31,937 POSTS
The master Cly is on the fire wall not the transmission, it will be next to the brake Cly
Mark (mhpautos)
Friday, April 25th, 2008 AT 9:40 PM
